AutoCAD 2010/2011/2012
Distinguished Contributor
andrew.nao
Message 1 of 8 (830 Views)
u command disabled
830 Views, 7 Replies
10-03-2012 11:30 AM
"u command disabled use undo command to turn on" has anyone ever gotten this message? it seems to only happen to 1 draftsman and i can figure out why
Valued Mentor
jonmcfarlandWS
Message 2 of 8 (826 Views)
Re: u command disabled
10-03-2012 11:39 AM in reply to: andrew.nao
There may be a script or routine that is disabling the command.  Is that system different than any other?
Jon
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
leothebuilder
Message 3 of 8 (825 Views)
You can disable a command by entering  _UNDEFINE in the command line followed by the command you want to undefine.
You can redefine a command by entering _REDEFINE in the command line, followed by the command you want to redefine.
pendean
Message 4 of 8 (800 Views)
10-04-2012 05:55 AM in reply to: andrew.nao
Look up UNDOCTL variable in HELP, it explains how to "turn it on".
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
andrew.nao
Message 5 of 8 (780 Views)
10-05-2012 10:31 AM in reply to: pendean
undo isnt turned off or disabled, just the use of "u" for undo gets disabled all work stations are the same
leothebuilder
Message 6 of 8 (777 Views)
10-05-2012 10:37 AM in reply to: andrew.nao
Dis you change the .pgp file and assinged "U" to some other command ?
andrew.nao
Message 7 of 8 (754 Views)
10-08-2012 07:59 AM in reply to: leothebuilder
the pgp file is ok
pendean
Message 8 of 8 (745 Views)
10-08-2012 09:30 AM in reply to: andrew.nao
Then you have an add-on or third party tool or startup choice someone at your end made for you that removed U from your access: it works fine here OOTB for all of us.
What you got?
