AutoCAD 2010/2011/2012
mies07
Message 1 of 9 (21,246 Views)
Accepted Solution
Turn off Grid
21246 Views, 8 Replies
05-30-2011 08:09 PM
Will someone please tell me how to set Autocad so that the silly grid is not displayed automatically at start-up? I have tried turning off F7, etc, and saving that to workspace, tried saving document as dwt, dwg in default template file location, etc, but no matter what I do the grid is always turned on when I launch Autocad.
Mike
You most likely have a startup, or a forced profile startup, that flips this on: here in plain AutoCAD 2012 once GRID is turned off in a file, it stays off in that file.
Do you have an ACADDOC.LSP file?
*Expert Elite*
pendean
Message 2 of 9 (21,244 Views)
Re: Turn off Grid
05-30-2011 08:12 PM in reply to: mies07
What exact version of R2012 are you running?
Are you noting it comes on in ALL files, or just when you start a new one?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
mies07
Message 3 of 9 (21,242 Views)
Re: Turn off Grid
05-30-2011 08:26 PM in reply to: pendean
Product Version F.51.0.0
Autodesk Product Design Suite Premium 2012
mies07
Message 4 of 9 (21,240 Views)
Re: Turn off Grid
05-30-2011 08:31 PM in reply to: mies07
Just want to set it so when it fires up the grid is not turned on. I have also set QNEW to same dwt, that was saved while grid was turned off, etc.
*Expert Elite*
pendean
Message 5 of 9 (21,224 Views)
Re: Turn off Grid
05-31-2011 05:44 AM in reply to: mies07
coopdetat
Message 6 of 9 (21,173 Views)
Re: Turn off Grid
06-03-2011 07:10 AM in reply to: mies07
I had the same problem.  Dean is right.  Each file you work on must have the grid turned off as the system variable (GRIDMODE) is stored in each file.  If the startup template file is saved with the grid off it should solve the problem for startup.  You can add (SETVAR "GRIDMODE" 0) to your startup customizations to force this in every drawing you open.
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 7 Professional 64-bit - Service Pack 1
Intel﴾R﴿ Core﴾TM﴿ i7-3820 CPU 3.60GHz; 16 GB DDR3 Dual Channel RAM
nVidia Quadro 4000; AutoCAD Civil 3D 2014, sp1
mies07
Message 7 of 9 (21,145 Views)
Re: Turn off Grid
06-04-2011 12:09 PM in reply to: coopdetat
Yes, I ended up just setting "load acad.lsp with every drawing" and included (setvar "GRIDMODE" 0). Since this file is customized locally,  I can leave default template files as is for those that do want to work with grid on at startup.
Thanks.
New Member
shafeie
Message 8 of 9 (20,546 Views)
Re: Turn off Grid
08-28-2011 03:35 AM in reply to: mies07
I've tried this trick and it's working...
click on new file and right click on your start template and choose properties and on properties window opened copy the location of file close properties window and new file dialog box on ACAD.
now click on open file and paste the location you'd picked from properties box on the filename
change the format to .DWT if necessary. Open your starting template and you can see the file is grid mode on just tap the F7 key to turn it off  ( or use "setvar gridmode 0") save the file and close it
now you should have your starting files in grids off.
I've tried this and it worked.
New Member
el_MI
Message 9 of 9 (20,449 Views)
Re: Turn off Grid
09-01-2011 02:28 AM in reply to: shafeie
Thanks. That worked great for me!
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
