AutoCAD 2010/2011/2012
Distinguished Contributor
henke
Message 1 of 9 (2,784 Views)
Trying to find out where in a drawing a font is being used
2784 Views, 8 Replies
12-02-2010 09:31 AM
I am cleaning up our company standart blocks and there is a font I want purged/deleted, but I keep getting the message that the font is in use.
I have checked the dimension styles, the multileader styles and cannot find it.
Is there a way to find out where it is being used?
*Expert Elite*
Message 2 of 9 (2,771 Views)
Re: Trying to find out where in a drawing a font is being used
12-02-2010 10:47 AM in reply to: henke
Attribute Blocks, Table styles?
Active Contributor
tkchaitu
Message 3 of 9 (2,762 Views)
12-02-2010 10:57 AM in reply to: henke
best way is to open the file in readonly mode, use explode till there are not objects left to explode and then use qselect to find the objects using that font.  Close the file without saving and open it in normal mode and change those objects.  If there are too many objects then you may want save as the exploded file only with the objects in question and use it as help to find all those objects while modifying the original file.
I hope it is helpful.
KC
petestrycharske
Message 4 of 9 (2,098 Views)
11-05-2013 10:46 AM in reply to: tkchaitu
I am not sure how to find the font, using quick select.  I see that one can use that tool to find the text styles, but users can override text styles when creating text objects.  Is there a way that one can only search for fonts, not just the text styles?  Perhaps I am missing something here and would gladly appreciate someone straightening me out.  Hope all is well and have a most blessed day!
Peace,
Pete
*Expert Elite*
pendean
Message 5 of 9 (2,087 Views)
11-05-2013 11:40 AM in reply to: henke
AutoCAD warned you the FONT is in use? I've never seen that behavior, it only warns you if a STYLE is in use and you can change that easily (or rename it to what you want it to be).
STYLE command is where to start.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Product Support
Volker_C
Message 6 of 9 (2,067 Views)
11-06-2013 08:51 AM in reply to: henke
You may have a empty text object in your drawing. Basically a placeholder for text where the content was deleted. Try using the Purge or -Purge command to remove "Zero-Length Geometry" and "Empty Text Objects.
The Technical Document TS18809891 discusses this and provides some additional methods for drawing file maintenance.
Hope this helps,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker Cocco
Support Specialist
Product Support
Autodesk, Inc.
*Expert Elite*
JGerth
Message 7 of 9 (2,059 Views)
11-06-2013 09:43 AM in reply to: petestrycharske
DXFOut, then search the DXF in a text editor searching for the font name?
*Expert Elite*
pendean
Message 8 of 9 (2,055 Views)
11-06-2013 09:45 AM in reply to: JGerth
If AutoCAD 2012 is being used, the freeware plug-in RadicalPurge (or RPurge) from the Exchange Apps Store does a great job of purging files.
*Expert Elite*
JGerth
Message 9 of 9 (2,042 Views)
11-06-2013 10:17 AM in reply to: petestrycharske
It might, since you're trying to clean things up, be a good idea to download StripMText.lsp, and eliminate all overrides in the MText objects.
just a suggestion to make your life easier down the road.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
