So there's an attribute I work with, and it consists of 210 pieces of text. The thing is, the guy that created it put all of the pieces of text on a layer I do not want them to be on. I want each piece of text to be on Layer 0. Is there a way to get all of the pieces of text to go on the Layer 0, without having to go into the attribute editor and click each individual piece of text and click the "properies" tab, and change it to 0?
Solved by bluefox. Go to Solution.
Actually, never mind. I figured it out. I figured out how to use the "sync" option in the BATTMAN command. I must've done something wrong the first time I tried it.
