AutoCAD 2010/2011/2012
New Member
CadGuy8609
Message 1 of 4 (102 Views)
Trouble with missinsg information in PDF
102 Views, 3 Replies
02-23-2012 11:21 AM
Since we switched to AutoCAD 2010 we have been having trouble with things disappearing when we plot to PDF.  I can not find a pattern with the things that are missing (i.e., area on page, layer, linetype, etc.).  When I do a plot preview everything appears the way it should and then after the PDF is made items are missing.  Typically after a couple of trys of rePDFing the drawing everything appears and works fine.  Does anyone have a solution for this?  I am using Vanilla AutoCAD 2010 and Adobe Acrobat 9 Pro.  Thank you.
New Member
lancemchatton
Message 2 of 4 (80 Views)
Re: Trouble with missinsg information in PDF
02-23-2012 03:17 PM in reply to: CadGuy8609
When I have had that problem, it turns out to be a nested xref issue.  If you think this may be the problem, let me know and I'll explain further.
New Member
CadGuy8609
Message 3 of 4 (69 Views)
02-24-2012 05:02 AM in reply to: lancemchatton
No Xrefs in the drawings at all, everything has been exploded to single lines, there aren't even any blocks in the file.
*Expert Elite*
pendean
Message 4 of 4 (66 Views)
02-24-2012 05:41 AM in reply to: CadGuy8609
Don't use Adobe Acrobat Pro for PDF creation and see if your problem goes away: start with the built-in PDF driver, and a generic PDF viewer like Foxit or others.
Oh, and if you haven't done it recently, empty your Windows profile Temp folder.
To find a problem, you have firstr identify the source by changing things.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Need installation help?
