AutoCAD Forum
too large flile
7 REPLIES 7
Message 1 of 8
mrkaplan
473 Views, 7 Replies
too large flile
hello
I need help with a dwg file. Its geometry content is light . it has no unreferenced xref of images.
it looks clean , its has been purged including appReg
still it weights 16 MB in 2004 format
when saved to 2000 format it takes 144 MB space
i cannot post it here because it is over 6MB even compressed
autocad freezes when either of these is perfomed
- audit and fix
-saving to a format older than 2000
-saving to dxf
-wblocking all or some of the file. (even wblocking a single object freezes.)
i suspect invisible content is involved , like AEC or similar . or perhaps language pack related ...
issue is the same with autocad 2012 and 2014 .
any help appreciated
7 REPLIES 7
Message 2 of 8
jggerth1
in reply to: mrkaplan
look at the linetypes listed in the drawing.  Best guess is that it's infested with DGN linetypes.  yes, or no?
Message 3 of 8
mrkaplan
in reply to: jggerth1
yes correct
except they are not dgn linetype but custom linetypes
Message 4 of 8
jggerth1
define custon linetype -- what are some examples?  can you post a screenshot of the linetype listing, and of the linetypes?
(they may not start with DGN in the name, but that does not mean they are not DGN linetypes)
Message 5 of 8
jggerth1
but, since you gcan get it down to a reasonable size in Acad Y2K format, why not just work with that in 2014?
Message 6 of 8
mrkaplan
here attached a capture of linetype manager on the file
Message 7 of 8
mrkaplan
dxfout and save back as dwg seems to do it .  thanks for pointing the right direction
Message 8 of 8
jgoessens148
You could try to make wblock from the drawing just select all you need. Normally the rubish in the drawing will be gone. Almost the same as making a dxf, but the function in  corporated from autodesk are not lost this way.
John
”Boost
