AutoCAD 2010/2011/2012
Valued Contributor
onthexmark
Message 1 of 15 (571 Views)
Accepted Solution
Thumbnail missing
571 Views, 14 Replies
02-15-2011 09:58 AM
When I insert a block, the little box in the upper right hand corner that shows the thumbnail, the thumbnail doesn't show up. Is this a variable I have turned off? If so what?
Mark
After all this time, the thumbnail is working today, I installed the service pack 1 last week maybe it had something to do with it.
Mark
*Pro
nestly
Message 2 of 15 (530 Views)
Re: Thumbnail missing
02-15-2011 04:31 PM in reply to: onthexmark
Is the "block" a block, or a .dwg.  As far as I know, there won't be any thumbs for .dwgs in the INSERT dialog box
Product Support
VinodBalasubramanian
Message 3 of 15 (510 Views)
02-15-2011 06:42 PM in reply to: onthexmark
Thanks nestly.
Onthexmark,
I presume you are talking about the preview during block insert. I have highlighted a screenshot for you. Let me know, if this is the one you have issue with.
Vinod Balasubramanian
Valued Contributor
onthexmark
Message 4 of 15 (481 Views)
02-16-2011 04:35 AM in reply to: onthexmark
Yes, this is what I'm talking about. It has alway had the preview there before.
Mark
Product Support
Message 5 of 15 (448 Views)
02-16-2011 10:43 PM in reply to: onthexmark
Thanks Mark. Can you check the system variable DRAGMODE. Can you check whether its ON or OFF. You can either set the value to 1 or 2. Let me know whether it helps or not.
Valued Contributor
onthexmark
Message 6 of 15 (437 Views)
02-17-2011 04:25 AM in reply to: VinodBalasubramanian
It is set on 2
Product Support
Message 7 of 15 (239 Views)
09-14-2011 07:59 PM in reply to: onthexmark
Hi Mark,
Are you still facing the issue.
Valued Contributor
onthexmark
Message 8 of 15 (229 Views)
09-15-2011 04:42 AM in reply to: VinodBalasubramanian
Yes, some drawing I'am working in have the thumbnails missing and some don't. I can understand why some do and some don't, I start with the same drawing blank.
Mark
*Expert Elite*
azrdgldr
Message 9 of 15 (223 Views)
09-15-2011 05:36 AM in reply to: onthexmark
This probably depends on the version of the drawing you are trying to insert.  2011 okay, 2004, probably no icon.  That's the way it's always been with the preview viewers.
Product Support
Message 10 of 15 (202 Views)
09-18-2011 09:00 PM in reply to: azrdgldr
Yes this can happen if you have blocks from Older file versions. Can you able to share one in which you can't see a thumbnail preview and also let me know the AutoCAD release in which it was created. This would help me to investigate further.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
