AutoCAD 2010/2011/2012
jh2274
Message 11 of 29 (152 Views)
Re: these are the errors i am getting
12-28-2012 01:17 AM in reply to: jh2274
Now getting this error, 1606 could not access network path
*Expert Elite*
Alfred.NESWADBA
Message 12 of 29 (148 Views)
12-28-2012 01:32 AM in reply to: jh2274
is this package one EXE? If so have you tried to unpack it with WinRAR and not starting it?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
jh2274
Message 13 of 29 (146 Views)
12-28-2012 01:42 AM in reply to: Alfred.NESWADBA
in doing that will it still auto unpack 2. I will try that now. I ran the microsoft fixit app and rebooted. wish me luck.
even with the new link from autodesk help I am still getting the original crc error on showcase as well
*Expert Elite*
Alfred.NESWADBA
Message 14 of 29 (141 Views)
12-28-2012 01:47 AM in reply to: jh2274
Did you run that before you "lost access to AutoCAD"? If so you now know the answer "why you lost...".
Do you get that error now/when extracting it with WinRAR?
- alfred -
Alfred NESWADBA
jh2274
Message 15 of 29 (140 Views)
12-28-2012 01:51 AM in reply to: Alfred.NESWADBA
 no, just now
yes just did
jh2274
Message 16 of 29 (129 Views)
12-28-2012 01:55 AM in reply to: jh2274
just got this error after running set up from extracted package
jh2274
Message 17 of 29 (128 Views)
12-28-2012 01:59 AM in reply to: jh2274
Log file
2012/12/21:23:00:37 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/21:23:00:37 James JAMES-PC Launch 2012/12/21:23:00:50 James JAMES-PC === Setup ended ===
2012/12/21:23:00:38 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/21:23:00:38 James JAMES-PC Launch 2012/12/21:23:00:52 James JAMES-PC PageOpen LaunchDialog   2012/12/21:23:06:06 James JAMES-PC PageOpen LicenseDialog   2012/12/21:23:07:55 James JAMES-PC PageOpen ProductInfoDialog   2012/12/21:23:08:20 James JAMES-PC PageOpen ProductSelectionDialog2   2012/12/21:23:09:40 James JAMES-PC PageOpen FullProgressDialog   2012/12/21:23:09:41 James JAMES-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\James\AppData\Local\Temp\vcredist_x86_2010.log 2012/12/21:23:09:51 James JAMES-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2012/12/21:23:09:51 James JAMES-PC PageOpen InstallCompleteDialog   2012/12/21:23:11:11 James JAMES-PC === Setup ended ===
2012/12/28:00:34:31 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:00:34:31 James JAMES-PC Launch 2012/12/28:00:34:48 James JAMES-PC === Setup ended ===
2012/12/28:00:34:33 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:00:34:33 James JAMES-PC Launch 2012/12/28:00:34:50 James JAMES-PC PageOpen LaunchDialog   2012/12/28:00:37:28 James JAMES-PC PageOpen LicenseDialog   2012/12/28:00:37:40 James JAMES-PC PageOpen ProductInfoDialog   2012/12/28:00:38:09 James JAMES-PC PageOpen ProductSelectionDialog2   2012/12/28:00:42:20 James JAMES-PC PageOpen FullProgressDialog   2012/12/28:00:42:21 James JAMES-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\James\AppData\Local\Temp\vcredist_x86_2010.log 2012/12/28:00:42:24 James JAMES-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2012/12/28:00:42:24 James JAMES-PC PageOpen InstallCompleteDialog   2012/12/28:00:42:46 James JAMES-PC === Setup ended ===
2012/12/28:00:43:50 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:00:43:50 James JAMES-PC Launch 2012/12/28:00:44:18 James JAMES-PC === Setup ended ===
2012/12/28:00:43:52 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:00:43:52 James JAMES-PC Launch 2012/12/28:00:44:17 James JAMES-PC PageOpen LaunchDialog   2012/12/28:00:44:27 James JAMES-PC PageOpen LicenseDialog   2012/12/28:00:44:27 James JAMES-PC PageOpen ProductSelectionDialog2   2012/12/28:00:44:47 James JAMES-PC PageOpen LicenseDialog   2012/12/28:00:44:47 James JAMES-PC PageOpen LaunchDialog   2012/12/28:00:45:23 James JAMES-PC PageOpen BeginDeploymentDialog   2012/12/28:00:45:36 James JAMES-PC PageOpen LaunchDialog   2012/12/28:00:48:01 James JAMES-PC PageOpen LicenseDialog   2012/12/28:00:48:12 James JAMES-PC PageOpen ProductInfoDialog   2012/12/28:00:48:45 James JAMES-PC PageOpen ProductSelectionDialog2   2012/12/28:00:49:41 James JAMES-PC PageOpen FullProgressDialog   2012/12/28:00:49:41 James JAMES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/28:00:52:16 James JAMES-PC Install DirectX® Runtime Succeeded  2012/12/28:00:52:16 James JAMES-PC Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/28:00:52:36 James JAMES-PC Install FaroSDK Succeeded  2012/12/28:00:52:36 James JAMES-PC Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/28:00:58:11 James JAMES-PC Install Autodesk® Material Library 2012 Failed Installation aborted, Result=1603 2012/12/28:00:58:16 James JAMES-PC Rollback FaroSDK Succeeded  2012/12/28:00:58:16 James JAMES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/12/28:00:58:16 James JAMES-PC PageOpen InstallCompleteDialog   2012/12/28:00:58:40 James JAMES-PC === Setup ended ===
2012/12/28:01:06:32 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:01:06:32 James JAMES-PC Launch 2012/12/28:01:07:15 James JAMES-PC === Setup ended ===
2012/12/28:01:06:37 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:01:06:37 James JAMES-PC Launch 2012/12/28:01:07:18 James JAMES-PC PageOpen LaunchDialog   2012/12/28:01:10:33 James JAMES-PC PageOpen LicenseDialog   2012/12/28:01:10:37 James JAMES-PC PageOpen ProductInfoDialog   2012/12/28:01:11:07 James JAMES-PC PageOpen ProductSelectionDialog2   2012/12/28:01:11:25 James JAMES-PC PageOpen FullProgressDialog   2012/12/28:01:11:26 James JAMES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/28:01:14:53 James JAMES-PC Install DirectX® Runtime Succeeded  2012/12/28:01:14:53 James JAMES-PC Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/28:01:15:08 James JAMES-PC Install FaroSDK Succeeded  2012/12/28:01:15:08 James JAMES-PC Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/28:01:21:27 James JAMES-PC Install Autodesk® Material Library 2012 Failed Installation aborted, Result=1603 2012/12/28:01:21:31 James JAMES-PC Rollback FaroSDK Succeeded  2012/12/28:01:21:32 James JAMES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/12/28:01:21:32 James JAMES-PC PageOpen InstallCompleteDialog   2012/12/28:01:21:36 James JAMES-PC === Setup ended ===
2012/12/28:01:43:33 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:01:43:33 James JAMES-PC Launch 2012/12/28:01:43:57 James JAMES-PC === Setup ended ===
2012/12/28:01:43:33 James JAMES-PC === Setup started on JAMES-PC by James === 2012/12/28:01:43:33 James JAMES-PC Launch 2012/12/28:01:43:54 James JAMES-PC PageOpen LaunchDialog   2012/12/28:01:46:26 James JAMES-PC PageOpen LicenseDialog   2012/12/28:01:46:39 James JAMES-PC PageOpen ProductInfoDialog   2012/12/28:01:49:03 James JAMES-PC PageOpen ProductSelectionDialog2   2012/12/28:01:49:23 James JAMES-PC PageOpen FullProgressDialog   2012/12/28:01:49:23 James JAMES-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/28:01:51:11 James JAMES-PC Install DirectX® Runtime Succeeded  2012/12/28:01:51:11 James JAMES-PC Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/28:01:51:24 James JAMES-PC Install FaroSDK Succeeded  2012/12/28:01:51:24 James JAMES-PC Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/28:01:57:09 James JAMES-PC Install Autodesk® Material Library 2012 Failed Installation aborted, Result=1603 2012/12/28:01:57:13 James JAMES-PC Rollback FaroSDK Succeeded  2012/12/28:01:57:13 James JAMES-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
*Expert Elite*
Alfred.NESWADBA
Message 18 of 29 (120 Views)
12-28-2012 02:05 AM in reply to: jh2274
starting the EXE -plus- when unpacking it with WinRAR ... when both actions show this error then the file is corrupt
I don't know your download-package, but by default if you see anything like "part2" or so ... that could mean that the download is not finished. Starting the unpackaging in that state makes me understanding why you get an error. Are you sure that
a) the download process has finished
b) the moving of the finished backup to the destination folder (you gave as destination when starting the download) is finished.
- alfred -
Alfred NESWADBA
*Expert Elite*
Alfred.NESWADBA
Message 19 of 29 (119 Views)
12-28-2012 02:06 AM in reply to: jh2274
Don't start the setup as long as you get CRC-failures while uncompressing.
- alfred -
Alfred NESWADBA
jh2274
Message 20 of 29 (118 Views)
12-28-2012 02:10 AM in reply to: Alfred.NESWADBA
autodesk sent it in two files, #1 as an exe file the other in .rar. I downloaded to the desktop then double click the exe file. it is self governing from there.
I then tried opening the first one in WinRar and ran the set up. Same issues.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
