AutoCAD 2010/2011/2012
Member
Maya2k11
Message 1 of 6 (6,298 Views)
The system cannot open the device or file specified.
6298 Views, 5 Replies
05-28-2011 10:28 AM
Starting Installations with Setup view screen the following error message:
C:\Users\Nombre\AppData\local\Temp\_AI4662.temp\x86\en-us\Components\adr2012\SetupDesignReview2012.msi
I need Help for solution.
Member
Maya2k11
Message 2 of 6 (6,297 Views)
05-28-2011 10:33 AM in reply to: Maya2k11
I have Laptop Toshiba Satellite A665-S6094 with i7 740QM, 4GB DDR3 1066, 640GB DDH, nvida 512MB video.
Active Member
allen_thompson
Message 3 of 6 (4,698 Views)
Re: The system cannot open the device or file specified.
01-14-2013 07:55 AM in reply to: Maya2k11
I am having the same problem installing Autocad Map3D 2013.
cpu is also trying to find setupdesignreview2013.msi.  Both file are located in my Temp folder???
*Expert Elite*
Alfred.NESWADBA
Message 4 of 6 (4,688 Views)
01-14-2013 10:05 AM in reply to: allen_thompson
the path in Windows is limited in length. So try to move your installation-files into a folder in a higher hierarchy (e.g. C:\TEMP) and try to start the installer again.
Another options might be to first extract the EXE (at least it's a self-extracting zip that you can unzip manually) and start the setup.exe in it.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Mentor
Rob.O
Message 5 of 6 (3,419 Views)
05-16-2013 10:36 AM in reply to: Maya2k11
I know the original post from this thread is a couple of years old, but we just experienced this same issue so I thought I would share the solution (at least what worked here).
Be sure to turn off your anti-virus software prior to running the install.  In our case, Trend was protecting some of the folders required for the install.
I have seen this in the past with other anti-virus software, but this is the first time I have seen it happen with Trend.
Hope it helps!
New Member
jgwinner
Message 6 of 6 (961 Views)
05-27-2014 09:52 PM in reply to: Rob.O
Great post - that was my problem as well.  My Dad had installed Trend on my laptop.  I guess you can't get a virus if you can't do installs :smileyhappy:
== John ==
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
