AutoCAD 2010/2011/2012
Member
3 Kudos
Post 1 of 6
The system cannot open the device or file specified.
6383 Views, 5 Replies
05-28-2011 10:28 AM
Starting Installations with Setup view screen the following error message:
C:\Users\Nombre\AppData\local\Temp\_AI4662.temp\x86\en-us\Components\adr2012\SetupDesignReview2012.msi
I need Help for solution.
Member
3 Kudos
Post 2 of 6
05-28-2011 10:33 AM in reply to: Maya2k11
I have Laptop Toshiba Satellite A665-S6094 with i7 740QM, 4GB DDR3 1066, 640GB DDH, nvida 512MB video.
Active Member
0 Kudos
Post 3 of 6
Re: The system cannot open the device or file specified.
01-14-2013 07:55 AM in reply to: Maya2k11
I am having the same problem installing Autocad Map3D 2013.
cpu is also trying to find setupdesignreview2013.msi.  Both file are located in my Temp folder???
1,216 Kudos
Post 4 of 6
01-14-2013 10:05 AM in reply to: allen_thompson
the path in Windows is limited in length. So try to move your installation-files into a folder in a higher hierarchy (e.g. C:\TEMP) and try to start the installer again.
Another options might be to first extract the EXE (at least it's a self-extracting zip that you can unzip manually) and start the setup.exe in it.
Good luck, - alfred -
Alfred NESWADBA
Valued Mentor
11 Kudos
Post 5 of 6
05-16-2013 10:36 AM in reply to: Maya2k11
I know the original post from this thread is a couple of years old, but we just experienced this same issue so I thought I would share the solution (at least what worked here).
Be sure to turn off your anti-virus software prior to running the install.  In our case, Trend was protecting some of the folders required for the install.
I have seen this in the past with other anti-virus software, but this is the first time I have seen it happen with Trend.
Hope it helps!
New Member
0 Kudos
Post 6 of 6
05-27-2014 09:52 PM in reply to: Rob.O
Great post - that was my problem as well.  My Dad had installed Trend on my laptop.  I guess you can't get a virus if you can't do installs :smileyhappy:
== John ==
