AutoCAD 2010/2011/2012
New Member
1 Kudo
Post 1 of 3
The ribbon does not have any tabs or panels currently loaded. Quick fix.
1671 Views, 2 Replies
12-14-2012 05:51 AM
To fix this, write  menuload   in the command panel. Then a box will apper.  klick on load, and choose acad.cuix.
If you now klick on the ribbon panel it will appear.
New Member
0 Kudos
Post 2 of 3
Re: The ribbon does not have any tabs or panels currently loaded. Quick fix.
02-18-2013 04:30 AM in reply to: veiby.monica
It is not showing as you have directed. It is just showing EXPRESS, when I type menuload. PLease help.
New Member
0 Kudos
Post 3 of 3
11-25-2013 11:39 AM in reply to: veiby.monica
Had the same problem.  After typing MENULOAD had to unload the AutocadLT file that was already loaded.  Then it let me load the CUI and all the panels reappeared.  Note-  before doing the above, I copied in an older version of the CUIX file into the folder just in case the current one had been corrupted.
Post to the Community
New Post
