We have a problem with AutoCAD R2011. The drafter made a rectangle, put some MText in it, and when he looked at the layout the text does not show up. It's on a visible layer, and when he takes some existing text and sticks it in the rectangle, it works fine. We are just using "MatchProp" to work around the problem. Is there a way to "globally" set the text properties of the drawing to those of a particular instance of text? Thanx.
Hello
Not sure to well understand your problem !?
If you select yours Texts/Mtexts and put them in frontorder , then Regen : have you the problem ?
Please check : SORTENTS = 127
Bye, Pat
Patrice BRAUD
What kind of rectangle? It almost sounds like a model view that happens to be rectangular in shape. Or it has a solid hatch with a color that matches that of the background.
Can you post the dwg file?
Don Ireland
Engineering Design Technician
Joe, is this annotation text? If so, then is thier CANNOSCALE set to 1:1 in modelspace? Or is it set to match the layout scale?
