Some of the files texts are displaying without smooth edge. how to solve this.
welcome @forums.autodesk.com !
Just the display is the problem or also if you plot?
For the display there are always optimizations active like no antialiasing, ... just to make commands like PAN, ZOOM, ORBIT, ... faster.
The only thing I know about some text objects difficult to read is if the text is
a) not aligned parallel to the current view
b) is not (excatly) on Z=0 ==> you can verify that by selecting the text, and in the property window change the Z-value of the insertion point first to 1 and then back to 0, after a _REGEN you might see a difference.
- alfred -
looking at the jpeg -- the text was not created normal to the view - lines that should be vertical are not, indicating that there's an angle involved.
Try using the PLAN command to normalize the display to the current UCS, and then verify that the rotation angle f the text is 0d0'0.0000"
i check the Z value.. its in 0, i did flattern. no change.. when i am ploting there also its not coming with smooth edge
there is no attachement here, maybe the filesize is to big (limit here is <= 1.5MB), if it's the size then remove most of the objects except that text-objects (in a copy of your original drawing) and send us that file.
Also try what JGerth suggested .... and verify what style/font that is.
- alfred -
See JGerth reply. Your text is not 0 degrees horizontal wtih respect to the view.
Can you please provide any other mail id. i tried to attach. but its not.
Have you reduced your file to just a few text objects (with that issue)? What's the filesize of this sample drawing?
And if you get a message while uploading fails, what is the message? Maybe it's working when you ZIP the file and upload the ZIP-file instead?
- alfred -
>> pls find
Nothing to find, sorry!
Do you try to attach a drawing into a mail-answer? Or do you upload the drawing here/using the forums access via internet-browser? The second option (login to the forum via internet-browser would be the better way for seeing what fails)
- alfred -
pls change dot and download the file
look to the attached PDF, I don't see anything strange in it (created from that "new block.dwg" using "DWG to PDF.pc3 with 1200 dpi).
I also attach a screenshot that shows the PDF with 200% enlarged (in Acrobat Reader X), also no problem afaik ... or do you see anything I miss?
Can you plot to PDF too and upload that so we can compare our results?
To the attachments: please rename the "NewBlock_B1_1004.txt" to "NewBlock_B1_1004.pdf" as I was not able to upload the PDF with the extension "PDF". Sorry!
- alfred -
