AutoCAD 2010/2011/2012
Active Contributor
kschu1
Message 1 of 9 (5,905 Views)
Text under dimension line
5905 Views, 8 Replies
01-11-2010 07:14 AM
Is there a way to place dimension text directly under the dimension line in addition to the normal dimension text above the dimension line?
*Jason Piercey
Message 2 of 9 (5,905 Views)
Re: Text under dimension line
01-11-2010 07:18 AM in reply to: kschu1
Try:
Text above the line\Xtext below the line
wrote in message news:6315883@discussion.autodesk.com...
dimension line?
Valued Mentor
tim.turner
Message 3 of 9 (5,905 Views)
01-11-2010 07:28 AM in reply to: kschu1
Nice little lisp "Dimnote.lsp" to add notes to dimensions here: http://www.cadalyst.com/management/news/tips-amp-tools-weekly-vol-12-no-26-7751
It would be nice to be able to pick multiple dims though, and have it remember typed entries in session.
Active Contributor
kschu1
Message 4 of 9 (5,905 Views)
01-11-2010 07:29 AM in reply to: kschu1
I inserted the "<>\Xtext" in the properties "Text override" dialog box and it worked perfectly. Thanks!!
Active Contributor
kschu1
Message 5 of 9 (5,905 Views)
01-11-2010 07:45 AM in reply to: kschu1
By using "\Xtext" it places text below the dimension line, but it also places the top and bottom text to close to the dimension line. By using "<>\P\Xtext" it corrects this problem. FYI
*Jason Piercey
Message 6 of 9 (5,905 Views)
01-11-2010 07:58 AM in reply to: kschu1
The "offset from dim line" found on the text tab in the dimension
style manager will adjust the spacing.
wrote in message news:6315930@discussion.autodesk.com...
*Dave Jones
Message 7 of 9 (5,905 Views)
01-11-2010 08:05 AM in reply to: kschu1
I was curious about your \P switch so I tried it here and it makes no
change in the location of the dim text in relation to the dim line.
Curious thing is though that the P switch won't work from the MText edit
dialog, only from the Properties pallette ??
Dave - DDP
Acad 2010 64 bit on Win 7 Pro
Intel I7-860 @2.8GHz
8GB DDR3 RAM
GeForce GTX260
*Jason Piercey
Message 8 of 9 (5,905 Views)
01-11-2010 08:09 AM in reply to: kschu1
If you are in the mtext editor, just press enter instead of
trying to use the formatting codes.
"Dave Jones" wrote in message news:6315956@discussion.autodesk.com...
Active Contributor
kschu1
Message 9 of 9 (5,905 Views)
01-11-2010 08:22 AM in reply to: kschu1
I may have responded to quickly to the issue - maybe more explanation. On the one dimension I tried it on, the top text and the below text both were touching the dimension line. I tried to adjust the "Text offset" with no change; so I used the \P\X coding and it worked.
When I tried it on other dimensions on my drawing the spacing was fine with the \X coding by itself. When I examined the difference between the dimensions it appears that when the dimension is aligned at an angle I have this problem of spacing that requires \P\X when it horizontal or vertical the \X coding is fine.
Announcements
Need installation help?
