AutoCAD 2010/2011/2012
Active Member
caddoodler
Message 1 of 28 (2,482 Views)
Text Lisp routine needed for merging text styles..
2482 Views, 27 Replies
03-11-2010 03:54 PM
ACAD Question...What's the command for merging one text style into another one? For example; I want to merge the text style 'ISTANDARD' to 'STANDARD' globally in an entire drawing. What is the quickest, fastest way to accomplish this...? After this is done i'll purge the old 'ISTANDARD' text style out of the drawing....TY
*Murph
Message 2 of 28 (2,481 Views)
Re: Text Lisp routine needed for merging text styles..
03-11-2010 04:12 PM in reply to: caddoodler
Rename if its a new text style not yet created, otherwise quick select the
text with the text style and change it in the property palette.
Murph
http://map3d.wordpress.com/
"CADDoodler" wrote in message news:6353463@discussion.autodesk.com...
*None
Message 3 of 28 (2,481 Views)
03-11-2010 04:23 PM in reply to: caddoodler
Load the attached. It will change ANY style to any style you want (if
both are in the dwg.)
Active Member
caddoodler
Message 4 of 28 (2,481 Views)
03-11-2010 04:24 PM in reply to: caddoodler
Yes that does work but i'm working on a very large facility background with hundreds of text groups..I can't check and verify each individual piece of text. Basically my instructions are to do away with the 'ISTANDARD' text style. my problem is that numerous groups of text are using this style. So i need to convert all those texts styles (ISTANDARD) to the 'STANDARD' text style. I remember using some kind of merge text style command in the past, however i can't remember what it was....?
Active Member
caddoodler
Message 5 of 28 (2,481 Views)
03-11-2010 04:30 PM in reply to: caddoodler
I want to TY in advance for your time spent working with me....
When i try and open that LISP file using notepad i get a bunch of jibberish headed with the message: "AUTOCAD PROTECTED LISP FILE".
Am I doing something wrong in trying to view/read it?
*Murph
Message 6 of 28 (2,481 Views)
03-11-2010 04:41 PM in reply to: caddoodler
Then look at the CAD Standards tools.
Murph
"CADDoodler" wrote in message news:6353477@discussion.autodesk.com...
Active Member
caddoodler
Message 7 of 28 (2,481 Views)
03-11-2010 04:47 PM in reply to: caddoodler
OK that's alot of info...i'll begin to digest that sites info and try to find the answer to my question.
TY for your time and insight :smileyhappy:
*None
Message 8 of 28 (2,481 Views)
03-11-2010 06:12 PM in reply to: caddoodler
You DO NOT OPEN THE FILE - you load it, thus . . .
type at the command line the following: (load "chgsty") - all with
parens. THEN, you type chgsty. OR . . . you can go to Tools and use the
Load Application. Just make sure the file is in a folder that autocad
can find first in either case.
*None
Message 9 of 28 (2,481 Views)
03-11-2010 06:13 PM in reply to: caddoodler
See my reply - it's a very simple program that will do EXACTLY what you
want.
*Murph
Message 10 of 28 (2,481 Views)
03-12-2010 03:41 AM in reply to: caddoodler
None, It's missing a function when I ran it.
Murph
wrote in message news:6353527@discussion.autodesk.com...
want.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
