we have aquired a big set of drawings with german text that needs to be translated in english. Is there any possibility to export the text, translate it outside autocad and the reimport it where it belongs?
Thanks in advance for help.
You can copy and paste text, into and out of Autocad.
I would suggest copying your text into google translate.
And when you paste the text back into Autocad paste it into an MTEXT box
Howard Walker
Yeah I agree the translations can be very dodgy at times.
The fun thing with google translate is to put in a simple sentence and then translate it to language1 then from language 1 to language2 and so on and so forth and then eventually translate it back to the original language and see how much the sentence has changed.
Howard Walker
Thanks for the replies,
unfortunately google translate is not an option, the drawings are mechanical fabrication drawing of rotating machines, so mistakes are not allowed. The idea was to export the text, send it to a translation company and the import it back, already that will be very time consuming due to the number of drawings involved.
I previously used ATTIN/ATTOUT to edit data outside autocad, I wonder if there is something similar for text.
Unless you have someone who actually speaks German, I'm afraid translation software is the only way it can be done.
Howard Walker
The problem is not the language itself but how to get the text in and out of the autocad drawings in a way that takes reasonable time.
@Exergy_cad wrote:Hello,
If you happen to have AutoCAD Mechanical, there is some kind of language converter tool in the Tools>Language menu.
- I've never used it myself, seems to be a straight phrase-for-phrase converter so would need serious setup work.
Googling finds plenty of references for third-party translation tools for AutoCAD.
if you had Autodesk civil 3D you would be able to export the text/points as shapefiles, these would come with.dbf files associated with them that would contain text and be editable in excel or an equivelent but it would be important not to move the text around from one box to another
As I said before copy and paste.
You can select text and copy and paste as if it is normal text as long as you are in the mtext box and select the text that way
Just create an mtext box and then paste your text in there.
Howard Walker
I do know how to use copy/paste and that is our last resort, I was hoping there was a faster way to process all the text but it seems there isn?t one.
Thanks for the suggestions, we will probably end up having a consultant making the changes in the autocad drawings or using Cad studio trans as you suggested.
There is no need to be rude, I tried to formulate the problem the best way I could, not everyone has lots of experience of online forums.
"There is no need to be rude..."
How right you are!
As you continue to use these discussion forums (as I think you should and hope you will), you will discover that there are certain members who, despite their "expert" status (or maybe because of it), apparently cannot help themselves. Eventually you learn that there is no way to stop it, so your best course is to simply ignore it and take the good with the bad.
