I have created a Site Datum point to be used as an Xref for a project and placed text on to show co-ords and angles and have done this to a text size no greater than 4mm.
When i go to scale up the datum point as an Xref in another drawing to match the drawing scale the picture looks great and correct. However, what look like text boxes are showing up as massively overscaled to the original drawing.
Why does this happen and how do I rectify it so everything is at the correct scale?
Any help greatly appreciated.
Sorry,
I gave up in the end and started from scratch again. Whatever the problem was doesn't exist on the new version, so I'm not going to beat myself up about it and nor should anyone else, so I'll consider it fixed.
Thanks anyhow.
