What is the correct way to utilize the ddchprop command with variables in LISP? I receive dxf files with text left justified at the insertion point, I want to center justify the text at the insertion point. I see numerous threads about changing the justification without movement (JUSTIFYTEXT), I want the movement. I would like to use a LISP routine so that when the initial dxf is created (3rd party software) the text can be formatted correctly before opening it in AutoCAD.
Solved by Alfred.NESWADBA. Go to Solution.
>> [...] I want the movement
Then select the text objects (e.g. using _QSELECT) and change the property "Justify" in the property window.
- alfred -
Thank you Alfred, but I believe I was unclear about my requirements. If I use _QSELECT in the routine, I get the dialog box, requiring a user to select the text. I want to run the routine without the user interface. The DXF in question has text on only one layer. Is there a way to invoke _QSELECT and pass variables to it? Initially the DXF contains mtext, I use the following to explode all mtext to single line text:
(setq :SSET (ssget "X" '((0 . "MTEXT"))))
(command "explode" :SSET "")
Now I want to set the justification to middle center, moving the text to the initial insertion point. I'm working on the following but have not yet tested it (from CAD Forums):
(defun c:rcm (/ e p11 p10 horn vertn vert hor en y)
(setq e (ssget "X" '((0 . "TEXT"))))
p11 (assoc 11 e)
p10 (assoc 10 e)
hor (assoc 72 e)
vert (assoc 73 e)
en e
(if (= (cdr hor) 0)
(setq p11n (cons 11 (cdr p10)))
(if (= (cdr hor) 0)
(setq en (subst p11n p11 en))
(setq horn 1
horn (cons 72 horn)
en (subst horn hor en)
(setq vertn 2
vertn (cons 73 vertn)
en (subst vertn vert en)
(entmod en)
(setq y "y")
(if (= (strcase y) "N")
(entmod e)
(c:rcm)
If you don't want QSELECT, then you already have found the LISP function SSGET ... there you can select all text objects.
I meant to use QSELECT as I would have used it to re-justify all text objects in a drawing just one command without the need for any development (well in model space and paperspaces seperately).
- alfred -
