AutoCAD 2010/2011/2012
KingDraw
Message 1 of 6 (5,160 Views)
Tangent Lines to Circles
5160 Views, 5 Replies
03-07-2011 03:36 AM
Hi All,
In my old version of Autocad 2007, To create a tangent line to a circle was easy, draw a circle, start a line and the select tangent from the Object Snap tool bar, click anywhere on the circle and the line would follow you.
In my latest version, 2011, I just cannot seem to get the same flexibility.  Surely there's got to be a way it's just that I cannot find it.  Can anyone help with this problem.
Best Rgds,
Dave R.
*Expert Elite*
rkmcswain
Message 2 of 6 (5,146 Views)
Re: Tangent Lines to Circles
03-07-2011 04:38 AM in reply to: KingDraw
Nothing has changed. It still works the same way in 2011.
Can you elaborate on "cannot get the same flexibility"?
*Expert Elite*
GrantsPirate
Message 3 of 6 (5,120 Views)
03-07-2011 07:46 AM in reply to: KingDraw
Make sure you are using line and not pline.  It works fine on my 2011 setup.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
SugarCAD
Message 4 of 6 (5,095 Views)
03-07-2011 11:26 AM in reply to: KingDraw
Not sure if this is 2011 specific, but I was just doing some tangent LINES and my line was snapping tangent to the other side of the circle (see example) The Blue Arrows are the Tan Snaps and the Blue Line is what was Given, the white line is what wanted and should have gotten.
*Expert Elite*
JDMather
Message 5 of 6 (5,069 Views)
03-07-2011 01:32 PM in reply to: GrantsPirate
....you could also use Geometry Constraints rather than osnaps and build rock-solid geometry relationships.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
KingDraw
Message 6 of 6 (5,042 Views)
03-07-2011 06:03 PM in reply to: KingDraw
Hi RK McSwain
What I meant was that once I create a tangent point on the circle the other end of the line is free to move and placed where required, in my case, at the end of another line.
BINGO!!  GOT IT.
What I needed to do was clear all object snap modes in the set up and just have the tangent one ticked.  That gave me the flexibility that I had with 2007.
Thanks all for your replies.
Best Rgds,
Dave R
Post to the Community
New Post
Need installation help?
