Using AutoCAD LT 2011
Model space, 1:100.
Using the same annotative text style in a table and in a standalone text object in the same drawing I get a huge difference in text size.
The stand alone text object sizes as i expect it to. The table always displays the text styles in its cells extremely small. Yet the table style in use uses the exact same text style as the text object.
Currently I use seperarate annotative text styles specifically for tables with a text height 100 times bigger than the styles used for text objects, leaders, dims etc. The table then displays the text at the same model space height as seperate text objects etc. This harmony continues in paper space too.
But I wonder if im overlooking something. Surely I could use the same text styles in both text objects and tables without problems.
Any comments are welcome.
