AutoCAD 2010/2011/2012
*Expert Elite*
cbenner
Message 1 of 6 (25,673 Views)
Superscript code
25673 Views, 5 Replies
05-16-2012 04:48 AM
I've been using AutoCAD for a looong time.  So long that I can remember that there used to be a "%%" code for subscript and superscript... but too long to remember what those codes were.  Or am I just getting senile? (wouldn't shock me).
Can anyone remember what those codes were?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
*Expert Elite*
Patchy
Message 2 of 6 (25,672 Views)
Re: Superscript code
05-16-2012 04:57 AM in reply to: cbenner
Use MTEXT and click on the @ sign, it will show some of them, also depends on which Font, it will show different sign.
*Expert Elite*
cbenner
Message 3 of 6 (25,660 Views)
05-16-2012 05:40 AM in reply to: Patchy
Thanks... that pointed me in the right direction... but the help files lie.  It gives you the code, and says it works with certain fonts, both TT and SHX.  Among them is Romans.  But when I try this, the unicodes show up as a ?.  Not cool.
Thanks anyway... you did answer the question. :smileyhappy:
ChrisB
*Expert Elite*
JGerth
Message 4 of 6 (25,644 Views)
05-16-2012 07:47 AM in reply to: cbenner
Here's one way to make a superscript of anything, in MTEXT.  Type in whatever verbiage you need, and where you want the superscript to appear, type in a fraction, e.g. 1/2.  You should get a dialog for stacking.  Accept whatever's there, then highlight the fraction, right click and choose Stack Properties.
In that dialog, black out the lower text,  edit the upper text to whatever you want, and change the Appearance Style to Tolerance".  voila
*Pro
murray-clack
Message 5 of 6 (25,602 Views)
05-18-2012 12:03 PM in reply to: JGerth
JGerth is on the right track, but there is a quicker method to avoid the extra step of removing the unwanted text.
The trick is to insert a carret (ie. "^") either after or before the text you want to super or subscript.
For example, let's say you want to Superscript "10.0ft2" Enter the text as follows: 10.0ft2^ (note the carret adter the "2"), now highlight the 2^, and then click the A/B stacking button
To do H20, enter the text as H^2O, higlight the ^2, and theb click the stacking button
For more MText tricks, check out the article I wrote for AUGI World:  http://www.augi.com/library/autocad-tricks-for-mtext-beyond-the-basics1
Distinguished Contributor
Dale.Bartlett
Message 6 of 6 (25,115 Views)
12-09-2012 03:56 AM in reply to: JGerth
Off Topic Comment>
I agree strongly with your footnote regarding "social media" re-posting.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
