AutoCAD 2010/2011/2012
brunobiazotti
Message 1 of 9 (544 Views)
Subtract objects created with "region"
544 Views, 8 Replies
08-15-2012 06:19 AM
Hi everybody!
One easy way for I calculate the weight of plates with many holes is creating regions and subtract the cuts as i need and after apply "LIST" command for get value of area . But, i cannot subtract the regions, in command line says :
"Command: region
Select objects: Specify opposite corner: 44 found
Select objects:
44 loops extracted.
44 Regions created.
Command: subtract Select solids, surfaces, and regions to subtract from ..
Select objects: 1 found
Select objects: Select solids, surfaces, and regions to subtract ..
Select objects: Specify opposite corner: 4 found
Select objects:
At least two solids, surfaces, or coplanar regions must be selected."
Why? what i do?
I appreciate any answer!
Not really sure, but I ran "All to Zero" macro and it worked.
Just add this to a button
^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;_chprop;_all;;_thickness;0;;^M;
JDMather
Message 2 of 9 (530 Views)
Re: Subtract objects created with "region"
08-15-2012 06:58 AM in reply to: brunobiazotti
Attach the file here that exhibits this behavior.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
brunobiazotti
Message 3 of 9 (521 Views)
08-15-2012 08:51 AM in reply to: JDMather
SugarCAD
Message 4 of 9 (515 Views)
08-15-2012 09:28 AM in reply to: brunobiazotti
You need to put them all at elevation 0.
Patchy
Message 5 of 9 (512 Views)
08-15-2012 09:34 AM in reply to: brunobiazotti
Nothing wrong with it.
Patchy
Message 6 of 9 (509 Views)
08-15-2012 09:38 AM in reply to: SugarCAD
Did you find any entities with elevation other than zero? I must have missed them.
brunobiazotti
Message 7 of 9 (497 Views)
08-15-2012 10:14 AM in reply to: Patchy
Yes, out of zero elevation. I not understand what happening. I check in the properties of the circles and show me that's ok ZERO, but is lie. The properties not show me the true value of the zero, the accuracy goes beyond that the display of the properties can show me.
SugarCAD
Message 8 of 9 (481 Views)
08-15-2012 12:04 PM in reply to: brunobiazotti
JDMather
Message 9 of 9 (474 Views)
08-15-2012 12:52 PM in reply to: brunobiazotti
brunobiazotti wrote:
 I check in the properties of the circles and show me that's ok ZERO, ...
Did you check out to 8 decimal places?
