AutoCAD 2010/2011/2012
Active Contributor
0 Kudos
Post 1 of 4
stuck in weird command
595 Views, 3 Replies
02-20-2011 04:52 PM
Hi all
i was just drawing a line at 45 degrees using the following command
Command: l
LINE Specify first point:
Specify next point or [Undo]: @2000<45
Specify next point or [Undo]: *Cancel*
Command: *Cancel*
Then i get this in the command bar
Command: @f
Unknown command "@F".  Press F1 for help.
It doesnt matter what i type or do i cant get out of this command.
What do i do???
Please refer to the attached file.
Cheers
Jthorgo
*Expert Elite*
1,603 Kudos
Post 2 of 4
Re: stuck in weird command
02-21-2011 08:00 AM in reply to: jthorgo
How are you cancelling the command in progress?
If you type .LINE (note the period) instead of L and repeated the same sequence, do you still get the issue?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
0 Kudos
Post 3 of 4
02-21-2011 11:30 AM in reply to: pendean
After i have drawn my line at 45 degrees i have a happit of hitting the esc key, therefore i get the "cancelled" in the command bar
and to fix the prblem i just restarted autocad and probelm is solved. But i m unsure how i even get to this command .
i have always drawn my lines at 45 degrees using the
Command: l
and never a problem.
jthorgo
*Expert Elite*
1,603 Kudos
Post 4 of 4
02-22-2011 05:10 AM in reply to: jthorgo
How about the second half of my reply? you need to make sure L is not something else now.
Does ESC tapping anywhere else repeat the issue?
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
