AutoCAD 2010/2011/2012
New Member
jessser84
Message 1 of 4 (281 Views)
Struggling with Limit Dimensioning, MMC, LMC ect..
281 Views, 3 Replies
02-04-2013 06:30 PM
Hello, New to the message board, but I am a student studing Mechanical Engineering.  I am struggling with MMC, LMC, Tolarance, Allowance. and using plus-minus, single limit, limit dimensions.  I am using 2012 AutoCad.  If anyone knows a place online that can better describe these, and help me with using them on drawings that would be wonderful.
*Expert Elite*
leothebuilder
Message 2 of 4 (260 Views)
Re: Struggling with Limit Dimensioning, MMC, LMC ect..
02-05-2013 06:41 AM in reply to: jessser84
On the dimension toolbar select "Tolerance" which brings up the Geometric Tolerance dialog box. Is that what you're after ?
Distinguished Mentor
steve216586
Message 3 of 4 (254 Views)
02-05-2013 07:48 AM in reply to: jessser84
Check out this tutorial:
http://www.youtube.com/watch?v=PQP6ZOKNHq0
*Expert Elite*
GrantsPirate
Message 4 of 4 (248 Views)
02-05-2013 09:01 AM in reply to: jessser84
For the dimensions you will create different dim styles for each of those that you listed, you might need several of each.
Use Tolerance command for the actual Feature Control Frame.
For Datums create one in Mulitleaders, that is what I have done.
For understanding GD&T without specific questions it is too wide open to help you.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
