AutoCAD 2010/2011/2012
Member
Cambodia
Message 1 of 17 (7,229 Views)
Strong Virus alert message in Autocad 2007 - 2011
7229 Views, 16 Replies
12-07-2010 06:27 PM
Hi All,
I've a very strong virus auto alert message in my Autocad 2007 -2011, i try to re installed the product and clear the registry editor as well as change all the AutoCad version, i also try to scan with Kaspersky and Avast but none of them can catch the virus. Unfortunately the auto alert message still keep alert while i'm opening the autocad design file,
Anyone here used to meet this problem? Please help me to give any suggestion would be a very big save!
Thank in advanced,
Cambodia
*Pro
nestly
Message 2 of 17 (7,223 Views)
Re: Strong Virus alert message in Autocad 2007 - 2011
12-07-2010 06:53 PM in reply to: Cambodia
I suggest Googling the name of the virus your Antivirus scanner reports.
Member
Cambodia
Message 3 of 17 (7,221 Views)
12-07-2010 06:57 PM in reply to: nestly
Hi Nestly,
Thank for your suggestion, However neither virus name nor reported from Kaspersky & Avast, This is just a disturb auto alert message while we opening the AutoCad design file, if we open 20 times the alert will display 20 times for each open. And antivirus can't catch this virus at all,
Thank,
Cambodia
*Pro
nestly
Message 4 of 17 (7,219 Views)
12-07-2010 07:04 PM in reply to: Cambodia
What does the message say?  Can you post a screenshot of the message?
Member
Cambodia
Message 5 of 17 (7,213 Views)
12-07-2010 07:24 PM in reply to: nestly
Hi Nestly,
Here is the message alert attachment,
-------------- Command Text Appear ----------------
Opening an AutoCAD 2007 format file.
Substituting [simplex.shx] for [DIN-RegularAlternate].
Substituting [simplex.shx] for [Gill Sans].
Substituting [simplex.shx] for [VNI-Avo].
Substituting [simplex.shx] for [ARCHS.SHX].
Substituting [@extfont2.shx] for [archstyl.shx].
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
Successfully Protected.
Successfully Protected.*Cancel*
Enter new value for DBLCLKEDIT <ON>:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
-------------- End Command --------------------------
thank,
Cambodia
*Pro
ampster
Message 6 of 17 (7,051 Views)
12-08-2010 08:26 AM in reply to: Cambodia
trying to state that everything you have posted doesn't indicate anything that you have a virus.
web-based forum software is fudging my reply...GIVE US NNTP ACCESS BACK!
Sorry for off topic banter.
Edited by
Discussion_Admin
Member
trung.le
Message 7 of 17 (6,674 Views)
01-23-2011 08:19 PM in reply to: Cambodia
 Hi Cambodia,
My company has just occured this alert message, I scanned with "Symantec Endpoint Protection"  but could not find any virus.
Whenever I open an Autocad file, a file "acaddoc.fas" is created at the same directory.
Please help us to solve this problem.
Thanks and regards.
Trung.
*Pro
Modman_4
Message 8 of 17 (6,618 Views)
01-24-2011 11:05 AM in reply to: trung.le
Please post a screenshot of the virus alert message, with a circle around the part you think is the virus message.
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Member
trung.le
Message 9 of 17 (6,574 Views)
01-24-2011 07:51 PM in reply to: Modman_4
Here is the screenshot : screenshot.JPG
Member
Cambodia
Message 10 of 17 (6,568 Views)
Re: Strong Virus alert message in Autocad 2007 - 2011 - Fixed!
01-24-2011 08:14 PM in reply to: Cambodia
Dear All,
I already found the solution,
Please search all files and folders in your computer with the string "*.fas", when your search result finish just delete all the result. Then you will get your autocad to work back :smileyhappy:
Cheer!
Cambodia
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
