AutoCAD 2010/2011/2012
Active Contributor
jasondbrown1
Message 1 of 7 (665 Views)
stretching to points in dynamic blocks
665 Views, 6 Replies
08-08-2011 06:32 AM
Is there a way to stretch a line and have it only stretch to certain points within a dynamic block?  I remember seeing/doing this once before, but cant find the commands that suggest the stretch stop at specified points.
any help is greatly appreciated.
Open the Properties palette for the Linear parameter
Value Set > Dist Type > Increment
Attribute tag names should be unique.
I fixed the block for you and it works for the 2x visibilities.  For the 1x, you either create another attribute for them or assign a move action to the existing 2x attribute so that the attribute stays centered.
*Pro
nestly
Message 2 of 7 (663 Views)
Re: stretching to points in dynamic blocks
08-08-2011 06:59 AM in reply to: jasondbrown1
Active Contributor
jasondbrown1
Message 3 of 7 (652 Views)
08-08-2011 09:07 AM in reply to: nestly
thanks.  that worked
i have another issue that coming up, maybe you could be of assistance.
I'm creating a visibility block that has a total of 6 options.  It's 2x4, 2x2, and 1x4 rectangles for lights.  the other three options are those, but with an emergency hatch.  Im using three separate attributes for light designations.  they will be shown on two separate options (ex: 2x4 and 2x4 emergency, etc)  I had this work before i add the hatch views.  Now, if i insert the block and pick the 2x4, set a designation to it, sometimes it'll show if i switch that light to an emergency.  If i come back and decide to change it to a 2x2, the designation goes away like it should b/c its associated with the 2x4.  well, my problems comes with me trying to change the attribute to another designation, but i get an error saying no attributes are associated with it.  If i'd chose the 2x2 first, it would work there, but not if i change to another option.  im not sure if this makes sense, but is it possible to have a dynamic block that has a shared attribute within the visibilities?
Message 4 of 7 (647 Views)
08-08-2011 09:20 AM in reply to: jasondbrown1
Can you post the block?
Active Contributor
jasondbrown1
Message 5 of 7 (641 Views)
08-08-2011 10:31 AM in reply to: ToanDN
here it is.
Message 6 of 7 (636 Views)
08-08-2011 11:05 AM in reply to: jasondbrown1
Active Contributor
jasondbrown1
Message 7 of 7 (621 Views)
08-09-2011 05:06 AM in reply to: ToanDN
OK I  see where i was wrong at.  I thought i just had to change the attribute prompt.
thanks for the help.
