hi guys,
i have this situation that our client require us to put cloud in each box and another cloud if there's 2 boxes, i done this using visibility.
but some drawings having 5 , 6 or 10 boxes near to each other. i try putting some parameters like linear scale but it scale the whole cloud, i just need only is to stretch the cloud just to cover the maximum number of boxes.
im just new here, maybe somebody would help me give an idea on how it easy to be done.
i will attached sample.
thanks,
Solved by pendean. Go to Solution.
I did some quick testing and this may be a solution for your problem.
I created a rectangular block with two stretch actions to it. (height and length)
When using this block for creating a revcloud:
1. Insert it into drawing.
2. Stretch it as necessary around your box.
3. Explode block.
4. Use REVCLOUD command on rectangle using the Object selection.
Repeat as necessary.
You may be able to create a lisp to do steps 3 & 4. It really doesn't take all that much time or effort though, in my opinion.
i appreciate the reply, maybe i have to make rectangle to highlight all the boxes i need then use revcloud.
thanks a lot guys,
Well, I didn't say I would do it that way. It seems easier to just draw a rectange then change to revcloud. But he said he already had a block.
well actually guys, i solved the stretching using steve idea but somehow in reverse and add some parameter but sometime it have overlapping in the arc because of the Array.
this is what i do.
1. create box then use REVLOUD.
2. explode CLOUD to make each one become ARC then create block.
3. go inside the block and add parameter LINEAR located in the Block Authoring Palettes and in the same palettes add action ARRAY & click one arc each side and add action MOVE & click the rest of the ARC on top of the CLOUD.
4. close the block.
