AutoCAD Forum
Stretch command without using grips for xclipframes is not working.
3 REPLIES 3
swingblue95
357 Views, 3 Replies
The only way to stretch the view for the xclipframe is by using the grips. I used to be able to stretch using the stretch command by doing a window on one of the corner frames and it would just stretch. I'm not sure what I did or who did it that turned something off and I can't do it anymore. However viewport, I could stretch with no problem. Please help, I'm feeling really annoyed. Thanks
3 REPLIES 3
pendean
in reply to: swingblue95
What is XCLIPFRAME set to?
What is FRAME variable set to?
swingblue95
in reply to: pendean
xclipframe is at 2
frame is at 3
I tried all variable and nothing...
Could you stretch your xclipframe without using grips but just using the stretch command by using window to pick a corner then stretch?
Any help is appreciated...
jggerth
I don't have 2012 around anymore, but the behavior you describe is typical for an XCLip in 2014.
”Boost
