AutoCAD 2010/2011/2012
Distinguished Mentor
18 Kudos
Post 1 of 6
Accepted Solution
Stop Publish from importing model tabs
381 Views, 5 Replies
12-04-2011 10:13 AM
How do I stop Publish from importing my model tabs?
The Publish command in 2009 I could control this in the Publish dialog (see attached). I can't find a corresponding setting in 2012.
In 3 years I have never plotted a model tab.
Jeff Paulsen
Civil 3D 2012 SP3 | Win 7 64-bit SP1
Xeon E5-1620 @ 3.60GHz, 16GB Ram | NVidia Quadro 600
Select the model tab in the list and I think it's a right mouse buttom option not to include them then or ever. Mines off now so I can't quite remember.
*Expert Elite*
1,210 Kudos
Post 2 of 6
Re: Stop Publish from importing model tabs
12-04-2011 10:55 AM in reply to: JeffPaulsen
imho when you start the command _PUBLISH AutoCAD will alway show all tabs (model & layouts) from the current drawing.
My way to work with publish is the following
  • change to my first Layout
  • press <SHIFT> and click on the last layout to be published (like a selection in Windows-Explorer, click first file then <SHIFT>+click last file)
  • release <SHIFT>
  • right-click ==> PUBLISH
so only the selected TABs will be listed in the PUBLISH-dialog.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
1,593 Kudos
Post 3 of 6
12-04-2011 12:25 PM in reply to: JeffPaulsen
Can we assume you are not a user of SHEETSET Manager?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
18 Kudos
Post 4 of 6
12-05-2011 05:55 AM in reply to: pendean
I use sheet set manager on all of my projects but at times I publish drawings that are not in a sheet set. For example, I usually do not put exhibits in a sheet set.
Jeff Paulsen
Valued Mentor
36 Kudos
Post 5 of 6
12-05-2011 08:24 AM in reply to: JeffPaulsen
18 Kudos
Post 6 of 6
12-05-2011 08:47 AM in reply to: TrevN
Thanks. You can right-click on any Sheet Name in the list (see attached).
Jeff Paulsen
Post to the Community
New Post
