AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 5
stacking numbers in dimension text-override?
6423 Views, 4 Replies
07-01-2009 12:14 PM
what is the keyboard shortcut to stack numbers as a fraction when you are overriding a dimensions value in the modify properties bar?
0 Kudos
Post 2 of 5
Re: stacking numbers in dimension text-override?
07-01-2009 12:35 PM in reply to: balldafter
Use DDEDIT on a pre-existing dimension.
Active Member
2 Kudos
Post 3 of 5
07-01-2009 02:06 PM in reply to: balldafter
You can use the ED command to modify the text of a dimension. Once in the editor, highlight over the "X/Y" formatted value, right click the mouse, and select "Stack" off of the context menu. Also note that the format "X#Y" autostacks to a diagonal fraction while the format "X^Y" autostacks to a horizontal fraction.
New Member
0 Kudos
Post 4 of 5
08-22-2011 12:56 PM in reply to: balldafter
If you're using Properties to edit your dimension, just add  \S  ;       EXEMPLE: 48\S1/2;" will give you this 48½"
*Expert Elite*
312 Kudos
Post 5 of 5
08-23-2011 07:30 AM in reply to: alx86
Thanks!  that's a new one, and one that i've wanted!
Post to the Community
New Post
