AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 3
Squeezed Text in an Block
563 Views, 2 Replies
10-07-2011 08:12 AM
The text in a title block I use keeps being squeezed together everytime I bring it into a new drawing. It is squeezed to the point were it is pushed on to the next line but then it overlaps the text below it. This only happens when I rotate the block to fit a landscape layout. It works fine when it is in portrait.
The text that keeps having the problems is not dynamic. It looks fine in the origanal drawing where the block was created and when I explode it the appears to be enough room.
Does anyone have any ideas on how to fix this?
Attached is the file I am having problems with and a picture of what it is doing. The text is the address in the lower right corner. It is the first line that is having the problem.
Your photo shows it is not arial font, when I opened your drawing with arial font, no problem at  all.
595 Kudos
Post 2 of 3
Re: Squeezed Text in an Block
10-07-2011 08:38 AM in reply to: suuGISCAD
33 Kudos
Post 3 of 3
10-07-2011 08:48 AM in reply to: suuGISCAD
Expand your mtext box and set your text style to middle center on some of the items in your block.  Re-examine the mtext and how you want it to act if you need long text strings.
