AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 5
Sort Order of Model Views in Sheet Set Manager
800 Views, 4 Replies
02-09-2011 11:39 AM
Is there a way to set the sort order in Sheet Set Manager for the Model Views tab?  Seems like a few releases ago it was alphabetical - now its random and almost impossible to locate a specific drawing in a large project.
Tried changing MAXSORT and it did not have an effect.
ORM
0 Kudos
Post 2 of 5
Re: Sort Order of Model Views in Sheet Set Manager
09-19-2012 04:53 AM in reply to: orm
Absolutely. I can't find anything! Surely there must be a setting or a fix? Or is nobody using SSM?
17 Kudos
Post 3 of 5
09-19-2012 05:52 AM in reply to: ScottCampbell
We just completed a 532 sheet project using SSM and had no troubles finding drawings in the sheet set..... that being said, you could always create subsets of one sort or another to help divide up your set and find things easier (we've done that from time to time and it helps somewhat).
3 Kudos
Post 4 of 5
02-06-2013 03:07 PM in reply to: orm
I have the same issue with Model View, it is not maintaining the order of the folders in the directory structure which are alphabetized.
Cheers
Paul
~~Laptop~~
Quad Core 2.3GHz Intel, 64-Bit, Win 7
16GB Ram, 2GB Graphics Card
256GB SSD
~~AU2009 Speaker~~
CV314-5: AutoCAD® Civil 3D® Design Straight Out of the Box: Going Where the Design Wizards Can't Always Go .....
*Expert Elite*
473 Kudos
Post 5 of 5
03-27-2013 05:37 AM in reply to: pkolarik
pkolarik wrote:
...you could always create subsets of one sort or another to help divide up your set and find things easier.
No, the OP is talking about the drawings listed on the Model Views tab, not the Sheet List tab.
Post to the Community
New Post
