AutoCAD 2010/2011/2012
New Member
lower1
Message 1 of 22 (40,102 Views)
Accepted Solution
(softlock license manager) is not functioning or is improperly installed
40102 Views, 21 Replies
06-26-2011 06:55 PM
I just installed autocad and this is what happened on the first boot.  I've uninstalled, rebooted, reinstalled and rebooted and still got this error.  What can I do?
Here is the exact error:  The security system (softlock license manager) is not functioning or is improperly installed
its a late reply, but since i got the same problem (and this is the first hit you get on google) i will tell you how to fix it
shut down the software
simply DELETE the files mentioned above!
Empty recycle bin!
Reopen the software, type in license key again
problem fixed :smileyhappy:
*Expert Elite*
TravisNave
Message 2 of 22 (40,044 Views)
Re: (softlock license manager) is not functioning or is improperly installed
06-29-2011 01:59 PM in reply to: lower1
This is most certainly a file permissions problem.  Make sure you give Everyone full rights to the following folders/files:
On Vista or Windows 7:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
On Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data.backup
Always install and run your Autodesk products with local Administrator privileges.
For faster responses concerning Autodesk licensing issues, please post your questions in the Installation and Network Licensing user forum here:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
New Member
rbastian1
Message 3 of 22 (37,781 Views)
01-24-2012 08:44 AM in reply to: lower1
This solution did not work.  Is there anything else I can try?  Do I need to uninstall and reinstall?  I am running Windows Vista 32 bit.
New Member
jaforii
Message 4 of 22 (36,091 Views)
04-22-2012 10:48 AM in reply to: rbastian1
Empty recycle bin!
New Member
danatami
Message 5 of 22 (31,668 Views)
12-15-2012 03:31 AM in reply to: lower1
what about windows 8??? i just can't find these files!
*Expert Elite*
pendean
Message 6 of 22 (31,663 Views)
12-15-2012 06:28 AM in reply to: lower1
Try setting Win8 to search hidden and locked folders
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
roadwayws
Message 7 of 22 (29,762 Views)
03-07-2013 03:07 AM in reply to: lower1
Here is a Ps to my last post, All my other programs in the suite work.
Now my "cad" just does not even try to open. just shuts down and I dont the Softlock error after deleting the files, and no place to put a serial number.
New Member
annie.graf.87
Message 8 of 22 (21,363 Views)
11-01-2013 07:03 PM in reply to: roadwayws
hi
i have the same problem
did you mange to fix yours?
if so pleas tell me how
New Member
nguyenminhtu_hy
Message 9 of 22 (19,362 Views)
11-28-2013 10:26 PM in reply to: annie.graf.87
Have you tried to start FLEXnet Licensing Service 64 service?
Member
babymeo18
Message 10 of 22 (17,441 Views)
12-25-2013 07:41 PM in reply to: jaforii
the autoCAD 2014 worked in my windows 8 but after the windows 8.1 update, i got that softlock license error and autocad won't open. i did all the steps mentioned and still did not work. i tried also reinstalling it more than 3 times already. i also tried removing the FLEXNET files.. but still did not work.. please help me. i need this for my project study. what should i do??
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
