I just installed autocad and this is what happened on the first boot. I've uninstalled, rebooted, reinstalled and rebooted and still got this error. What can I do?
Here is the exact error: The security system (softlock license manager) is not functioning or is improperly installed
Solved by jaforii. Go to Solution.
Solved by TravisNave. Go to Solution.
Thanks Jafori,
Problem solved using your instructions. Much appreciated.
<run msconfig
<services
<make sure that this one is CHECKED....
FLEXnet Licensing Service 64 service
solved....
i am having the same problem but i have upgrade to windows 10 can anyone help
yap, it's work 100000000%. LOL
thank you so much Travis .... He is the man
let me repost.
This is most certainly a file permissions problem. Make sure you give Everyone full rights to the following folders/files:
On Vista or Windows 7:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
On Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data.backup
Always install and run your Autodesk products with local Administrator privileges.
Very usefull, another option is windows+r >> msconfig
Click the Windows Start button and in the Run box type "Services."
Select the "Services" node.
In the services list, locate FlexLM Licensing Service and FlexLM Licensing Service 64 and enable it
Check to ensure the services are not disabled:
you all have to do is follow the above comment , it works on me
be sure to turn off the licensing in ms config before deleting
