Installation & Licensing
(softlock license manager) is not functioning or is improperly installed
32 REPLIES 32
Message 1 of 33
140578 Views, 32 Replies
I just installed autocad and this is what happened on the first boot.  I've uninstalled, rebooted, reinstalled and rebooted and still got this error.  What can I do?
Here is the exact error:  The security system (softlock license manager) is not functioning or is improperly installed
32 REPLIES 32
Message 21 of 33
Thank you!!!!!!
Message 22 of 33
Thank you!!!!! you save me!
Message 23 of 33
isale2BTYE
Thanks Jafori,
Problem solved using your instructions. Much appreciated.
Message 24 of 33
<run msconfig
<services
<make sure that this one is CHECKED....
FLEXnet Licensing Service 64 service
solved....
Message 25 of 33
blackhead42
i am having the same problem but i have upgrade to windows 10 can anyone help
Message 26 of 33
pendean
in reply to: blackhead42
Older software is not supported in WIn10 http://autode.sk/1IY4C2X
You might have to buy a fix http://www.longbowsoftware.com
Message 27 of 33
derryck
Hi
I have the same problem, but I do not know what files you ar referring to?
Cheers
Derryck
Message 28 of 33
in reply to: jrco86
yap, it's work 100000000%. LOL
thank you so much Travis .... He is the man
let me repost.
This is most certainly a file permissions problem.  Make sure you give Everyone full rights to the following folders/files:
On Vista or Windows 7:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
On Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data.backup
Always install and run your Autodesk products with local Administrator privileges.
Message 29 of 33
garou01
Very usefull, another option is windows+r >> msconfig
    Click the Windows Start button and in the Run box type "Services."
    Select the "Services" node.
    In the services list, locate FlexLM Licensing Service and FlexLM Licensing Service 64 and enable it
Message 30 of 33
garou01
Check to ensure the services are not disabled:
  1. Click the Windows Start button and in the Run box type "msconfig"
  2. Select the "Services" node.
  3. In the services list, locate FlexLM Licensing Service and FlexLM Licensing Service 64.
  4. Right-click the entry and click "Properties" or enable it.
  5. Set the "Startup Type" to "Automatic."
  6. Click "Start" to start the service and click "OK."
  7. Start the program to test.
Message 31 of 33
in reply to: Pontooon
you all have to do is follow the above comment , it works on me
be sure to turn off the licensing in ms config before deleting
Message 32 of 33
chrisklar
I'm having the same problem, which files do I delete for Windows 10, please help!
Message 33 of 33
derryck
in reply to: chrisklar
Hi
I don’t remember this unfortunately 🤦‍:male_sign:
Administrator Productivity
