Is there a setting I can change so if I am drawing an object (line, polyline, etc.) if I am snapping to a contour line, the objects will NOT take on the elevation of the contour line?
Solved by Patchy. Go to Solution.
awesome......thanks a lot Patchy! I also found the "flatten" command for after objects are drawn, but this takes that step out of it!
