AutoCAD 2010/2011/2012
Active Member
kmankov
Message 1 of 5 (248 Views)
Accepted Solution
slow responce time
248 Views, 4 Replies
11-04-2011 12:57 PM
responce time for entering comand is slow. For example if I press m (for move) then hit enter right away AutoCAD would not react, so every time i have to hit enter 2 or 3 times right after every command (really annoying). Probably I'm too quick for the programm, but I hope there is a way to make it faster (like that control for double clicking in windows). Or may be there is any other way. Please bring any suggestions. Thank you.
try to play with dynamic input (<F12>) and also one possible reason could be if you have not docked the commandline-window into the application window ... and worst case for that would be undocked plus on the second monitor.
- alfred -
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (228 Views)
Re: slow responce time
11-04-2011 03:50 PM in reply to: kmankov
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
kmankov
Message 3 of 5 (210 Views)
11-07-2011 03:06 PM in reply to: kmankov
Thank you. That solves my question. Hopefully Autodesk will fix that.:smileyhappy:
*Expert Elite*
Alfred.NESWADBA
Message 4 of 5 (194 Views)
11-08-2011 01:34 AM in reply to: kmankov
Have you sent them the problem and the solution? If not they can't, you didn't tell us which of my above tips solved it for you :smileywink:
- alfred -
Alfred NESWADBA
Active Member
kmankov
Message 5 of 5 (161 Views)
12-12-2011 09:16 AM in reply to: kmankov
I just closed command line. Immidiately it become super fast. So the problem was with command line.
PS. Good drafter does not need command line anyway. ctrl+9 and ctrl+0 rule and modified acad.pgp rule :smileyhappy:
Announcements
Need installation help?
