AutoCAD 2010/2011/2012
New Member
tommyrihu
Message 1 of 5 (759 Views)
Slow "save as" in Autocad 2011 with 2007 format
759 Views, 4 Replies
12-18-2012 04:35 AM
Hi
ihave big problem to save in Autocad 2011, then we save in 2007 DWG format it takes up to 3-4 min even local this problem exist, reinstalled i computer totally clean, no antivirus just windows 7 and updated,
even  disabled fidelity. then i save in 2010 format it goes fast.
anyone any ideas?
regards
Tommy
Alfred.NESWADBA
Message 2 of 5 (739 Views)
Re: Slow "save as" in Autocad 2011 with 2007 format
12-18-2012 10:04 AM in reply to: tommyrihu
are you working in plain AutoCAD or has the drawing seen sometimes a vertical product like ACA or Civil3D or ....
What happens if you try command _AUDIT or open the file with command _RECOVER?
What happens if you try to run command _-EXPORTTOAUTOCAD (if this command is available to your AutoCAD)?
- alfred -
Alfred NESWADBA
Distinguished Contributor
fxcastil
Message 3 of 5 (711 Views)
12-19-2012 03:25 PM in reply to: tommyrihu
The slow save/conversion from AutoCAD2011 to an earlier version is typical and normal.
New Member
tommyrihu
Message 4 of 5 (699 Views)
12-19-2012 11:59 PM in reply to: fxcastil
Thanks for answer ! but if this is typical for Autocad 2011 ,why this behavoir only happens for som users then saving in 2007 format? /Tommy
Alfred.NESWADBA
Message 5 of 5 (696 Views)
12-20-2012 12:38 AM in reply to: tommyrihu
we have to differentiate to what are the times for saving normal and saving back to an old format.
If normal save uses 2 minutes, then saving back may use 3-4 minutes, depending on some settings like SAVEFIDELITY.
If normal save is done within a few seconds, then 3-4 minuts is not usual.
- alfred -
Alfred NESWADBA
