I am trying to create a simple lisp to close and save the drawing. But while doing so I want the command to select the first layout tab in the drawing but each drawing has a different named layout tab. How can I do this? As of right now it is selecting the model tab but I don't want to close the drawing looking at the model tab. here is what I have,
(defun C:clo()
(command "ctab" "model" "")
(command "zoom" "e")
(command "qsave")
(command "close")
Solved by Kent1Cooper. Go to Solution.
You can load up pbejse's (layorder) routine here [there are other such routines elsewhere], which returns a list of paper-space Layout names in left-to-right order, and set the current tab to the first name in the resulting list with:
(setvar 'ctab (car (layorder)))
