AutoCAD 2010/2011/2012
Valued Contributor
1 Kudo
Post 1 of 12
Shortcut key for "File-close" command
4583 Views, 11 Replies
11-24-2011 03:29 PM
Can someone tell me how to create a Shortcut key "Alt + c"  for "File  - close" command? I like the same seeting as my Inventor seeting, and the Inventor is so easy to setup my Shortcut keys use "Tools-Customise-Keyboard".
Thanks in advance.
Andy
Distinguished Contributor
1 Kudo
Post 2 of 12
Re: Shortcut key for "File-close" command
11-24-2011 06:12 PM in reply to: Andy_Kuang
Standard windows... CTRL+F4
Valued Contributor
1 Kudo
Post 3 of 12
11-24-2011 06:38 PM in reply to: Tony_R
Thanks for your help, but my hand not big enough, to do it all the times not quite easy.
Andy
1 Kudo
Post 4 of 12
11-24-2011 07:08 PM in reply to: Andy_Kuang
Then go to TOOLS - CUSTOMISE - INTERFACE, select KEYBOARD SHORTCUTS. Then try and work out how to use that abortion of a dialogue box to actually asign a keystroke combination to do anything because I'm damned if I can figure it out.
1 Kudo
Post 5 of 12
11-24-2011 07:25 PM in reply to: Tony_R
http://www.ellenfinkelstein.com/acadblog/create-a-custom-keyboard-shortcut/
Looks like you can't use ALT for some bizzare reason. So perhaps use CTRL+ALT+C.
Valued Contributor
1 Kudo
Post 6 of 12
11-24-2011 07:58 PM in reply to: Tony_R
Thanks Tony,
I created a shortcut key "CTRL + ALT +X" for my  "File-close" command.
It is great!
Andy
Valued Contributor
0 Kudos
Post 7 of 12
10-03-2012 09:40 AM in reply to: Tony_R
I'm having a hard time understanding CUI as well.
I'm trying to assign standard CTRL+W to close the file (not exit software) but I'm having no luck. I'm currently using 2012.
*Expert Elite*
15 Kudos
Post 8 of 12
10-03-2012 11:42 AM in reply to: DevinCurrie
What about clicking on that X in the top right hand corner ?
Valued Contributor
0 Kudos
Post 9 of 12
10-03-2012 11:51 AM in reply to: leothebuilder
Yes that's what I am doing now however I prefer the CTRL+W option
Valued Contributor
0 Kudos
Post 10 of 12
10-05-2012 11:02 AM in reply to: DevinCurrie
Someone may find this info useful, I have achieved my objective by doing the following:
1) Open CUI > Keyboard Shortcuts > Shortcut Keys
2) then follow instruction as per Help
To create a shortcut key, you start by dragging a command from the Commands List pane to the Shortcut Keys node in the Customizations In <file name> pane. Once you create a shortcut key, you assign a key combination to it.
Post to the Community
New Post
