AutoCAD 2010/2011/2012
Valued Contributor
david.dixon
Message 1 of 2 (554 Views)
Sheet Set Manager issue - dwg links being reassigned
554 Views, 1 Replies
02-08-2013 06:24 AM
I am having a strange issue with Sheet Set Manager that I have never seen before.  I am using SSM with ProjectWise in AutoCAD Civil 3D 2011 (ProjectWise is the new variable in my workflow due to recent change in employer).  When I import a layout as a new sheet, some but not all of my existing sheets become relinked to other unrelated sheets.  For instance, sheet C2070 becomes linked to sheet E2002, sheet C2071 becomes linked to sheet IC2010, etc, etc.  About 25 of 130 sheets become relinked.  This affects plotting from SSM because AutoCAD send back errors saying ti cannot find the page layout / setup.  I notice that the "Sheet ID" embedded in the .dst is the same number between sheets that get switched.
I am not sure what is causing this.  I am in the process of downloading a utility called SSMPropEditor from JTBWorld to help edit the .dst file separately from AutoCAD, especially that "Sheet ID" field which is not visible in SSM.
Has anyone else experienced this issue and have a better fix?
David Dixon
Senior Civil Designer
Google+
New Member
jscott.applegate
Message 2 of 2 (222 Views)
Re: Sheet Set Manager issue - dwg links being reassigned
12-12-2013 11:19 AM in reply to: david.dixon
David,
We're having the same issue with PW ss4 and AutoCAD Civil 3D 2012.
Anytime a new sheet is added or one is removed from the SSM we have to check all of the Expected Layouts.
If SSMPropEditor worked/works please post here.
Scott Applegate
Technicall Designer III
Post to the Community
New Post
Need installation help?
