AutoCAD 2010/2011/2012
Active Contributor
0 Kudos
Post 1 of 6
Sheet Set Manager gone
4013 Views, 5 Replies
09-16-2010 10:24 AM
I have a user that did something to his AutoCAD and his SSM will no show. Ctrl+4 doesnt work, SHEETSET doesnt work, and all other ways to bring up the sheet set manager.
This every happen to anyone before and any way to get it back short of re-install
-Randy
*Pro
169 Kudos
Post 2 of 6
Re: Sheet Set Manager gone
09-16-2010 12:22 PM in reply to: randoshadow
The missing pallete may be floating off-screen where you can't see it.  Try this:
1) Open the CUI
2) Pick the workspace with the missing feature.
3) Highlight the missing feature in the upper left window.
Turn the missing feature ON,   associate with an edge on your screen, ALLOW docking, and turn OFF AutoHide
Click Apply, then OK
Active Contributor
1 Kudo
Post 3 of 6
11-03-2010 01:21 PM in reply to: randoshadow
I'm having the same issue in ACAD 2011 and the above method isn't working. In 2010 it works fine, but I can't get it to display in 2011.
I can see that it's turned on in the View ribbon, and I have it set in CUI to Show: Yes, Orientation: Right, Allow Docking: Yes, and Auto Hide: Off. I'm in the correct workspace (the one where it's set in CUI).
I can use SHEETSET and SHEETSETHIDE, and even OPENSHEETSET and I get no errors, but it doesn't display the palette.
Jason Rossitto
Beth Israel Deaconess Medical Center
Active Contributor
1 Kudo
Post 4 of 6
11-18-2010 06:41 AM in reply to: randoshadow
A user here is having the same trouble with AutoCAD Mechanical 2011.  I went through all of the Workspaces and set the Sheet Set palette Show=Yes and set a size for the window (as some were set to 0) along with no transparency and it still does not show.  I'm told it was working yesterday which leads me to believe that something else is affecting the Sheet Set palette from showing.  Any help would be appreciated!
Active Contributor
1 Kudo
Post 5 of 6
11-18-2010 06:56 AM in reply to: jasongetsdown
I just installed the 1.1 product update and the sheet set manager has returned! It wasn't one of the issues shown in the patch readme, but after the patch I am able to open sheet sets in 2011.
I'll post here if it disappears again.
Jason Rossitto
Active Contributor
1 Kudo
Post 6 of 6
11-18-2010 07:15 AM in reply to: randoshadow
Thank you VERY much!!
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
