AutoCAD Forum
Setting up profiles
5 REPLIES 5
KevinPinks7697
376 Views, 5 Replies
Setting up profiles
I only use AutoCAD once in a blue moon and I see that AutoCAD 2010 has changed quite substantially from what it used to be. How do I set up a profile in AuotCAD so that everytime I open it, my toolbars etc.. are how I prefer them?
5 REPLIES 5
pendean
in reply to: KevinPinks7697
You simply save your current WORKSPACE after you move things around: the command is WSSAVE.
double-z
in reply to: pendean
can't he also create a new "profile" under tools>options>profiles (use 'add to list' button)?
(note, i don't know a lot about the differences between workspaces and profiles)
pendean
in reply to: double-z
Workspaces are all about the autocad display/locations of buttons, toolbars, pulldown menus etc.
Profiles are about locating custom folders, menu files, settings, resources etc.
Two different functions.
double-z
^ thanks pendean.
(i learned something new)
i hope this helps you kevin.
KevinPinks7697
Thanks everyone
”Boost
