AutoCAD 2010/2011/2012
KevinCassel
Message 1 of 4 (1,739 Views)
Setting the scale for primary and alt units
1739 Views, 3 Replies
11-09-2011 06:40 AM
Im trying to make the promary units metric and the alt to engineering but the scale factor is wrong. It thinks that 6 meters is 1.8288". Any sugestions?
And if anyone had the same problem as me, this is how you fix it;
Format> Dimension Style> Modify
In the Alternate Unit tab, change the Multiplier for alt units to 39.37007874015748
1 meter should now be 3'-3.37"
tcorey
Message 2 of 4 (1,729 Views)
Re: Setting the scale for primary and alt units
11-09-2011 09:15 AM in reply to: KevinCassel
Correct alt units from metric to engineering is 0.03937007874016.
By the way, six meters is over 19 feet, no where near the 1.828 inches you said in your post. I don't know where you got that conversion. The closest I can get is 5 centimeters equals 1.96 inches.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
KevinCassel
Message 3 of 4 (1,726 Views)
11-09-2011 09:43 AM in reply to: tcorey
I didnt think that was the converion, i said for some reason my dimension thought this was right.
 "Im trying to make the promary units metric and the alt to engineering but the scale factor is wrong. It thinks that 6 meters is 1.8288".
 I know that six meters is 19'-8.22"
But thanks for the number, although I imported a file with the right conversion and got it that way.
KevinCassel
Message 4 of 4 (1,725 Views)
11-09-2011 09:48 AM in reply to: KevinCassel
