AutoCAD Forum
setting plotting
2 REPLIES 2
Ashoo89
176 Views, 2 Replies
setting plotting
I've got a total of AutoCAD files, and I want to print it, but every time I work from printing settings for each file and this tires me, I want to do, and one set for each file in order to be ready ... Thank you very much
2 REPLIES 2
hwalker
in reply to: Ashoo89
Welcome to the Forums
You need to explore using PAGESETUP.
Create one in a TEMPLATE and then you can IMPORT the pagesetup when you start plotting your drawings.
Howard Walker
Left Handed and Proud
pendean
PUBLISH command, with the tip above, is even quicker if you use layouts.
SSM (sheet set manager) is also an option, designed to manager sets of drawings for a single project and includes publishing (plotting) options.
”Boost
