I've got a total of AutoCAD files, and I want to print it, but every time I work from printing settings for each file and this tires me, I want to do, and one set for each file in order to be ready ... Thank you very much
Solved by pendean. Go to Solution.
Solved by hwalker. Go to Solution.
Welcome to the Forums
You need to explore using PAGESETUP.
Create one in a TEMPLATE and then you can IMPORT the pagesetup when you start plotting your drawings.
Howard Walker
