AutoCAD 2010/2011/2012
Active Member
sjancski
Message 1 of 4 (4,060 Views)
Accepted Solution
Setting Autocad 2012 to always save as previous version?
4060 Views, 3 Replies
08-09-2011 09:43 AM
So i am considering upgrading to autocad 2012 on one of our workstations.  But I want to know what versions can be set in the Options...Save As dialog box.  Can someone with 2012 please check which versions AutoCAD 2012 can be configured to automatically save to? (For compatability with other, older Autocad users in our office like 2009 and 2010).
Thanks!
*Expert Elite*
JDMather
Message 2 of 4 (4,044 Views)
Re: Setting Autocad 2012 to always save as previous version?
08-09-2011 12:56 PM in reply to: sjancski
see attached
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
hardin
Message 3 of 4 (4,030 Views)
08-09-2011 03:08 PM in reply to: sjancski
Also keep in mind that 2012 uses the same dwg format as 2010, so you should be okay in that respect.
For the 2009ers, you'll have to save to the 2007 format.
Johneng
Message 4 of 4 (4,023 Views)
08-09-2011 04:37 PM in reply to: sjancski
I  recommend you try the software before you buy it. Just run the software in trial mode for 30 days and see how it works for you. This way you can see first hand if 2012 plays well with others for your specfic work enviroment before you commit money for it.
Trial down load can be found here
http://usa.autodesk.com/autocad/trial/
Announcements
Need installation help?
