AutoCAD 2010/2011/2012
tbolt650cc
Message 1 of 6 (465 Views)
Sending a DWG to PDF w/ multiple sheets
465 Views, 5 Replies
01-24-2013 08:55 AM
I have to two sheets layed out in one drawing in Auto CAD 2012, a tilte sheet and the building plan. How can I send that to one PDF file (one PDF file with both sheets) using the 'DWG to PDF.pc3' option?
Use  PUBLISH rather than individual plot and set the output to a multipage PDF
Hmmm possibly. If you Go FILE, the command PUBLISH should be about halfway down, or type _PUBLISH at the command prompt. Then the dialog opens select the tabs you want plot then hit the publish options buttion, in the General DWF/PDF options make sure multi-sheet file is selected.
Nik-D
Message 2 of 6 (462 Views)
Re: Sending a DWG to PDF w/ multiple sheets
01-24-2013 09:28 AM in reply to: tbolt650cc
tbolt650cc
Message 3 of 6 (458 Views)
01-24-2013 09:53 AM in reply to: Nik-D
Would you call that, "Batch plotting to PDF"?
Nik-D
Message 4 of 6 (449 Views)
01-24-2013 11:14 AM in reply to: tbolt650cc
tbolt650cc
Message 5 of 6 (446 Views)
01-24-2013 11:50 AM in reply to: Nik-D
Got it. I was over looking the layout tab for the multiple sheets. Thank you much!
Nik-D
Message 6 of 6 (439 Views)
01-24-2013 01:01 PM in reply to: tbolt650cc
No Problem
