AutoCAD 2010/2011/2012
0 Kudos
Post 1 of 11
Selection window problem
517 Views, 10 Replies
11-16-2011 10:36 AM
I'm having an issue using the 'window selection' method for selecting serveral items.
In the job I'm currently working on, we had HSS 4x4 columns, and we're changing to HSS 8x8 columns. So I inserted a block representing the 8x8 columns, and placed them at all the necessary gridline intersections. However, i didn't delete my 4x4 columns first. So as I was selecting my 4x4 columns, which are in now centered inside my new 8x8 columns, I thought I could just use the window selection by making sure that my selection box wasn't covering the entire 8x8 column, but would be covering the entire 4x4 column. To do this I would zoom in and click the first corner of my selection box at a point to the upper left of the 4x4 column, but below the upper left corner of the 8x8 column, then I would zoom out and drag my selection box to the right across my drawing to select all the column on one gridline.
The problem is, that when I zoom out and drag across, the selection box expands or something and ends up selecting both my 4x4 columns that are on the inside and the 8x8 columns that are on the outside. Even though I started the selection box in a location that shouldn't have been able to window around the 8x8 columns. It only happens when I zoom out far enough. I don't know how far out it takes, but if I was only selecting say 3 columns, it would work just fine, but if I zoomed out farther to grab 4 or more columns, then it would selection both the 4x4 and the 8x8 columns.
See the attached file to understand objects and selection window.
*Expert Elite*
594 Kudos
Post 2 of 11
Re: Selection window problem
11-16-2011 11:01 AM in reply to: allstardrafter
Picture doesn't let people give it a test.
0 Kudos
Post 3 of 11
11-16-2011 11:18 AM in reply to: Patchy
Ok, here is the AutoCad drawing of my project column locations and situation. There are two lines of columns, along grid 'M' and grid 'N'.
When I started my selection process, I've been starting with the column at grid '12' and dragging my box to the right to grid '20' on either grid 'M' or grid 'N'.
Feel free to try it out and see if you can get it to happen for you.
*Expert Elite*
594 Kudos
Post 4 of 11
11-16-2011 11:39 AM in reply to: allstardrafter
It messed up and selected all columns like you said.
0 Kudos
Post 5 of 11
11-16-2011 11:45 AM in reply to: Patchy
I looked through my options, but I couldn't find anything on the selections tab or the display tab, that fixed it.
*Expert Elite*
594 Kudos
Post 6 of 11
11-16-2011 11:54 AM in reply to: allstardrafter
I used "Select Similar" for the 4x4 column and deleted them, too easy if you have vertical Autocad.
0 Kudos
Post 7 of 11
11-16-2011 12:07 PM in reply to: Patchy
Yes select similar definetly works, but I do have some other area in this job that have HSS 4x4 columns that are going to remain, so I don't want them selected.
I went ahead and just selected that individual columns to delete, but I was just wondering if anyone had experienced this or had a solution for it.
*Expert Elite*
594 Kudos
Post 8 of 11
11-16-2011 12:25 PM in reply to: allstardrafter
It's crazy alright, happened both 2008, and 2012.
Since it's dynamic block, why did you have to insert new 8x8 col's , you coud select all the 4x4 and change to 8x8.
0 Kudos
Post 9 of 11
11-16-2011 12:32 PM in reply to: Patchy
Well, on my actual project it was both W-shape columns and HSS columns that were changing, so I just brought in new blocks. But for the discussion on here, HSS examples were easier to visualize.
I don't have any other autocad versions on my computer right now, but I don't remember this ever happening in 2011. I've acutally found serveral silly errors that occur in 2012, that never did in 2011.
Product Support
55 Kudos
Post 10 of 11
12-10-2011 07:08 PM in reply to: allstardrafter
I downloaded your drawing and attempted to reproduce the issue you are seeing with the selection windows. I was able to use the window selection as long as the objects I wanted to select were visible in the drawing area, but with a selection area of that size it's difficult to see the edges of the columns to finish out the selection:
Standard window selection example on Screencast.com
Try this, use the window selection but type in "WPOLY" on the command line for a windowed polygon selection. Just make sure to zoom out and get all the columns into view before pressing enter to end the selection command:
WPOLYGON Selection example on Screencast.com
If this resolves the issue please let us know and click the "Accept as solution" button to help others find answers when searching the discussion groups.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Post to the Community
New Post
