AutoCAD 2010/2011/2012
Active Member
polymk
Message 11 of 13 (71 Views)
Re: selection filter
02-10-2012 08:05 AM in reply to: hardin
Hi Hardin,
"if all you're wanting to do is select the 'hatching'"
yes that's the main problem. I have to "clean" a drawing which not respect the norms.
Your tips are good, i used SELECT/FENCE and it's a long work, but efficient.
For pPendean : I post on Message #6 2 files (block and drawing).
Thanks again.
Have a nice WE.
MP
Active Contributor
dallasn
Message 12 of 13 (60 Views)
02-10-2012 03:34 PM in reply to: polymk
What are you using to convert the file?
With Adobe illustrator you can often erase the hatches as one entity before conversion.
Active Member
polymk
Message 13 of 13 (53 Views)
02-11-2012 03:25 PM in reply to: dallasn
I used "pdf to dxf" and "any pdf to dwg".
the both software gave me the same result.
I will think about adobe illustrator, thank you for the tips.
PM
